Knock when starting '99 4.6
Old Aug 6, 2006 | 10:50 PM
Beaux Duke's Avatar
Default Knock when starting '99 4.6
My Crown Vic has developed a knock when starting. It happens cold or hot but most often when cold. It'll do it when hot but only if it's been shut down for a while.
It sounds to me like oil starvation of the lifters. I'm using Castrol 5W-30 with a Purolator filter that has the anti-drain back valve.
It just turned 75k and the knock started about 5K ago. The knocking stops after about 3 - 5 seconds. Seems to be just a little behind the oil pressure gage, in other words the gage shows full pressure then a second or two later the knocking stops.
Any suggestions?
Old Aug 6, 2006 | 10:59 PM
94 4x4 ranger's Avatar
Default RE: Knock when starting '99 4.6
I would use a regular oil filter. it does sound like it starves for oil
Old Aug 6, 2006 | 11:04 PM
Beaux Duke's Avatar
A "regular oil filter"?
Do you mean a filter without the anti drain back valve or a Ford/Motorcraft filter?
I've been using the same model Purolator filter for about 40K miles with no problems.
Old Aug 6, 2006 | 11:10 PM
Yes one with out a drain back valve.
ROFFL
Oct 5, 2007 12:26 PM
mach
May 1, 2006 03:47 PM
e_de_anda
Feb 5, 2006 05:01 AM
blewis
Nov 13, 2005 02:44 PM
FRANKENSTEIN69
Jul 14, 2005 03:06 PM
