2002 windstar sel
Old Aug 16, 2006 | 03:27 PM
coucci's Avatar
Default 2002 windstar sel
Hey there. I have a problem that i just cant figure out.
2002 windstar sel the engine light keeps coming on. i bought a code reading and it keeps coming up as p0402. I tried unplugging the vacuum to the egr and driving the van for a bit and the lite does not go off. Every once in a while the ligt will go off and on usually around the time my wife fills up, dont know if that is just a coincidence or not.
Just wondering if anyone has any ideas.
Thanks Mike
Old Aug 16, 2006 | 03:56 PM
94 4x4 ranger's Avatar
Default RE: 2002 windstar sel
The code p0402 Exhaust Gas Recirculation Flow Excessive Detected .This code I woud think is the EGR is stuck open or EGR related. Does it run rough?
Old Aug 16, 2006 | 04:05 PM
coucci's Avatar
It seems to run fine at idle and high speed!!
Old Aug 16, 2006 | 04:11 PM
Do you have any tool's like a vacuum hand pump? Or a socket set?
Old Aug 16, 2006 | 04:19 PM
coucci's Avatar
i have the basic tools anything else i can borrow from buddies
Old Aug 16, 2006 | 04:28 PM
I would first look for and loose,cracked vacuum lines.If none are found I would suspect carbon build up at the EGR this is a common problem. I would also buy a new EGR gasket a 1 can of gumout. Remove the EGR valve and spray gumout in the passages. Scrape and clean old gasket. Replace gasket then replace the egr. Then disconnect the battery for 5 minutes to clear the code.
Old Aug 16, 2006 | 06:30 PM
Mulletman's Avatar
9 times out of 10 the DPFE sensor has went bad on you. Also check the hoses leading to the sensor.
linny
Apr 4, 2015 02:13 PM
henryts77
Dec 4, 2013 08:07 PM
mrdgzpm
Mar 7, 2013 02:37 PM
BSB
Oct 28, 2009 09:41 AM
avileskim76
Aug 13, 2007 04:36 PM
