Where is purge valve located
Old Aug 18, 2006 | 12:57 PM
JimMaher's Avatar
Default Where is purge valve located
Where is the purge valve located on 95 Ford ranger. I am trying to eliminate the P1443 code.
Old Aug 18, 2006 | 05:39 PM
94 4x4 ranger's Avatar
Default RE: Where is purge valve located
This is what I found for this code P1443 :This assembly connects the intake manifold to the charcoal canister and the assembly is made up of hoses, a valve and a sensor. On my 1997 Ranger, it is located near the front of the engine compartment on the driver’s side (the canister is right behind the driver’s side headlight). Apparently, if there are any cracks in the hoses, or if the valve or the sensor wears out, this will cause the check engine light to come on, and return the P1443 code. After looking around on the web for a couple of days, I was lucky enough to find a few part numbers for the canister purge solenoid/flow sensor assemblies:
F57Z-9C987-AB Canister Purge Solenoid/Flow Sensor
Assembly - 2.3L
F57Z-9C987-CA Canister Purge Solenoid/Flow Sensor
Assembly - 3.0L
F57Z-9C87-BA Canister Purge Solenoid/Flow Sensor
Assembly - 4.0L
Old May 6, 2009 | 07:03 AM
Quichang's Avatar
The hoses are missing on my canister. Do you have a pic or schematic of where the hoses are suppose to go?
Aquakittie
Jan 27, 2012 02:16 PM
bossdc13
Aug 2, 2010 01:01 PM
rangerman95
Dec 24, 2009 12:34 PM
bbensten
Dec 5, 2006 01:28 PM
