Window motor on 95 T-bird
Old Aug 27, 2006 | 02:25 AM
Davetheslave's Avatar
Default Window motor on 95 T-bird
The window motor on my 95 T-bird is not going up gets stuck half way up and if you push the switch and push the window with your hand it will go up. I am trying to replace the motor, but it is tight in there also do I have to remove the rivites, and do the passenger side and drivers side swap out can one be used for the other because if I get one at the junk yard probably passenger will of had less use. any help is greatly appreciated because the Hanes manual is not much help at all.
Old Aug 27, 2006 | 10:24 AM
94 4x4 ranger's Avatar
Default RE: Window motor on 95 T-bird
My parts book say's these window motor's are different.
rc10mm
Jan 2, 2007 08:50 AM
SV6Mustang
Dec 15, 2006 12:59 PM
Davetheslave
Sep 20, 2006 12:39 PM
Davetheslave
Sep 1, 2006 12:59 AM
Davetheslave
Aug 27, 2006 10:22 AM
