power steering help
Old Feb 16, 2005 | 06:07 PM
98hd's Avatar
Default power steering help
Got a '96 taurus. Had to replace the power steering pump. Got that done, and the system bleed. I started it up, and then cycled the steering to see if it worked, and if I turn the steering wheel until it stops turning, something (can't see as I'm in the car) locks up and the belt starts slipping and smoking. Works if I turn the other way too, buy only if I turn it all the way.
Is the P/S pump that much harder to turn when you max out the steering wheel? The belt got coated in alot of P/S fluid from when the pump went out, so it may be putting *just* enough resistance to make it spin on the pulley?
Looking for any suggestions.
thanks
Old Apr 26, 2005 | 03:38 PM
ugothim's Avatar
Default RE: power steering help
remove the belt,,spray the pulleys down with brake parts cleaner.. wipe the pulleys down with a clean rag and install a new belt..should do the trick..also you NEVER want to turn the wheel to that full stop position ..it will damage the pump for sure ...
cmccraine922
Dec 5, 2013 09:30 PM
jaymzsun
Mar 10, 2011 08:13 PM
skuntz01
Sep 7, 2009 08:17 AM
taurus98
Sep 29, 2008 08:15 AM
CodyAlanB5
Nov 6, 2005 11:08 PM
