'89 Bronco II oil pressure sending unit location
Old Sep 21, 2006 | 10:39 PM
Dr. Jeff's Avatar
Default '89 Bronco II oil pressure sending unit location
Could use a drawing / schematic to help expedite replacement of the oil pressure sending unit (showing exactly where the bugger resides).
Have the $ 9 replacement part (dealer wanted $ 125 to do the job) just need to locate it...
A response ASAP would be appreciated.
Old Sep 21, 2006 | 10:44 PM
94 4x4 ranger's Avatar
Default RE: '89 Bronco II oil pressure sending unit location
[sm=welcomesign.gif]What motor?
Old Sep 21, 2006 | 10:55 PM
If it is a 2.9 here you go [hr]Under hood, driver side, lower engine area, beneath exhaust manifold, left side of oil level sender, above oil pan rail, mounted in block.[hr]As Per Autozone
Old Sep 22, 2006 | 11:04 AM
Dr. Jeff's Avatar
First, 94 4x4 ranger, my apologies for not responding until now (been a little busy with other responsibilities).
Yes, it is a 2.9 and I thank you for the word picture, however (being a visual learner), before I climb underneath to do the deed, would you (or anyone else reading this) be able to provide a drawing (embed picture in post) just to make sure I don't cause myself any avoidable mechanical grief?
BEATRICE1
Aug 21, 2011 09:53 PM
david paul
Dec 6, 2009 03:03 PM
bmkeiffer
Dec 2, 2007 09:35 AM
93f250xlt4x4
Nov 25, 2006 01:02 AM
Roanbadger
Jul 1, 2006 12:07 AM
