4eat blowing front seal
Old Sep 28, 2006 | 11:54 PM
roger33's Avatar
Default 4eat blowing front seal
My Escort is blowing out the front pump seal (torque converter) on the 4eat automatic. Any chance it may be a bad pump letting pressure build up behind the seal? Does anyone know how to pull the pump out? I have a spare trans with a good pump but I don't know how to get it out.............Roger
Old Sep 29, 2006 | 03:39 AM
roger33's Avatar
Default RE: 4eat blowing front seal
Another idea is maybe when the torqu converter goes into lockup the hydrolic pressure is leaking by and getting behind the front pump seal and blowing it out. The car drives and shifts fine, just blowing the seal off ts boss.......Roger
Old Oct 11, 2006 | 12:23 PM
Has this vechile had recent tranny work done on it ?? Normally you gotta use some type of seal driver, to install these seals in the pump,,,, I have to wonder if the correct seal is being used,,,, Or if it was damaged when installed,,, or not being driven all the way in.,,,,, you may want to try putting a very SMALL bit of loctite around the outer flange of the seal. An then drive it into the case,,,,, normally theres a machined lip in the pump housing that the seal is suppose to stop against on the back side
There should be a case vent somewhere on the trans ,, that may be plugged allowing excessive pressure build up
ryansteph
Mar 1, 2008 10:20 AM
Superkick42
Nov 17, 2007 10:40 AM
dsljay
Oct 15, 2007 10:58 AM
yowie61
Sep 25, 2007 06:46 PM
roger33
Sep 29, 2006 05:55 PM
