Aod 84 replacing 91
Old Feb 27, 2005 | 11:29 AM
f1504x41991_78's Avatar
Default Aod 84 replacing 91
I have a 91 Mercury grand Marquis and I have an 84 what would I have to do in order to use the trany out of the 84 in the 91 both are aod but different linkage conections.
Old Feb 27, 2005 | 12:27 PM
truckpuller's Avatar
Default RE: Aod 84 replacing 91
You can change the linkage from trans to the other by pulling the pan . You should check to be sure that tail shaft lenghts are the same they do have 2 differant lenghts and also the drive gear teeth for the speedometer you need to count teeth on the gear on the shaft otherwise speedo might be off. Other than this it should work.
Good luck
65chero
Oct 8, 2006 01:32 AM
f1504x41991_78
May 8, 2005 02:18 AM
Badd_Company
Feb 26, 2005 12:44 PM
corder13
Nov 23, 2004 06:42 PM
Josh
Apr 18, 2004 12:30 PM
