92 ford E4od lock up clutch
Old Oct 14, 2006 | 07:00 PM
suntattoo80's Avatar
Default 92 ford E4od lock up clutch
ok i just got this thing for a killer deal. and it shutters like mad when the lock up clutch or converter clutch is in lockup. how can i disable the lock up to see if this is the problem???is there a plug or wire i can cut remove???
Old Oct 15, 2006 | 08:32 AM
94 4x4 ranger's Avatar
Default RE: 92 ford E4od lock up clutch
[sm=welcomesign.gif][hr]You can try to pull plug's until the problem go's away.[hr]Or if you are skilled enough pull the pan to check it out.
Old Oct 15, 2006 | 02:13 PM
The converter shudder is eliminated with an OD command to off? Converter shudder on higher mileage units isn't uncommon.. Sometimes a fluid change will help with the shudder if not to far gone, or an upgrade change to Mercon V, as the fluid breaks down over time/mileage from heat/shear/contamination ect...
The TCC solenoid wire is Purple/Yellow at the trans harness.. This pinout harness/plug chart may be of help..
http://www.powertraincontrolsolution...4R70-89-97.pdf
makuloco2000
Jul 22, 2014 08:33 PM
jmelees
May 17, 2012 02:38 PM
llewjay
Dec 2, 2008 04:32 PM
PTT
Sep 8, 2005 12:53 AM
Mobile AV
Aug 17, 2005 04:01 PM
