Heater Core Replacement
Old Oct 15, 2006 | 01:46 AM
VicOnVogues's Avatar
Default Heater Core Replacement
So I tried To replace my heater core. but for some reason i could not get the dash out far enough to get to the heater core box. If anyone could tell me a easy way to get to the heater core that would be awsome. I really dont want to have to pay someone a lot of money to replace such a cheap part..and winter is here already its getting cold so i need some heat asap. thanks Rob
Old Oct 15, 2006 | 08:18 AM
94 4x4 ranger's Avatar
Default RE: Heater Core Replacement
I dont know if you need to take the dash out on this model.[hr]Do you have a repair manual?[hr]If not pick one up at any major auto parts store they will give you step by step instruction's.[hr]If you lived closer mabey id look at it for you.[hr]Good luck.
Old Oct 15, 2006 | 06:10 PM
way2old's Avatar
If you have all the bolts out of the side of the dash panel, you can pull it up high enough to rpll the heater box out from under the dash. It will not come out straight. It needs to be rolled forward then pulled out.
Old Oct 15, 2006 | 10:15 PM
I have a usur manual but it really doesnt help all that much..what about the bolts in the engine compartment.. according to the manual there are 3 under there that need to be undone.. and i couldnt find them either.. and how many are there on the side that you are talkin about?.. thanks Rob
Old Oct 18, 2006 | 10:07 PM
way2old's Avatar
I think the ones you are looking for are on the top of the heater/ac plenum across the top. There is one that is down inside the passenger fender well close to the blower motor. The side bolts on the dash are the big ones that hold dash to the frame. You also need to remove all small pieces under the dash so it will pull up high enough.
Old Oct 18, 2006 | 11:03 PM
sk for the help man. You do by any chance know haw many big bolts there are? I am gonan try to do it again 2maro if it is nice out here. i just had to get a bunch of work done, such as the cylinder #7 coil pack, and some other stuff.. cost a lot of money. and now i really need to do the heater core myself..thanks Rob
Old Oct 19, 2006 | 10:00 PM
way2old's Avatar
Should only be one on each side. Remove the plastic trim and you will see it.
Budsjlm
Oct 11, 2009 09:36 PM
jmbrush
Jun 29, 2009 07:19 PM
marinos90209
Dec 2, 2008 05:10 PM
Gladfelter13
Mar 11, 2008 12:04 AM
dmanlyr
Jul 9, 2005 03:34 PM
