aod form a 5.8 to 5.0
Old Mar 1, 2005 | 08:02 PM
f1504x41991_78's Avatar
Default aod form a 5.8 to 5.0
Can anyone tell me if an aod transmission from a 91 5.8 bolt up to a 91 5.0
Old May 6, 2005 | 08:29 AM
Ticky's Avatar
Default RE: aod form a 5.8 to 5.0
yes if they r both windsors they will but if the 5.8 is a clevo it will not go without changing the bell housing i think
Old May 6, 2005 | 08:05 PM
solo_one's Avatar
The Cleveland was only built till 81, so you shouldnt have any problems.
Old May 8, 2005 | 02:18 AM
truckpuller's Avatar
Several minor things to check, shift linkage, tail housing lenghts which there was two differant lenghts, and also the number of teeth on the output shaft which runs the speedo. Other than these minor details it will bolt right in.
Good luck
wjfulkerson
Jan 12, 2009 10:41 PM
KINGDELL
Apr 13, 2008 10:01 AM
canadaeast
May 29, 2007 11:10 AM
dngrrngr93
Aug 15, 2005 05:26 PM
Josh
Apr 18, 2004 12:30 PM
