Go Back   Ford Forum - Enthusiast Forums for Ford Owners > Ford Cars > Ford Taurus
Welcome to Ford Forum!
Welcome to Ford Forum,
Old 10-23-2006, 05:43 PM
dallas dallas is offline
Default 96 wagon will start but not run
It's actually a '96 Sable. Maybe someone here can help. This link will explain everything I've done so far: http://www.automotiveforums.com/vbul...d.php?t=633593
I know someone else must have encountered this problem.
Thanks.
Old 10-23-2006, 08:56 PM
giantfan1226 giantfan1226 is offline
Default RE: 96 wagon will start but not run
if you give it gas when it starts will it stay running?
if so, i would just replace the idle speed motor(iac)
sometimes cleaning it wont do anything
hope this helps
Old 10-23-2006, 09:30 PM
Giving it gas doesn't help. It will run if I spray carb cleaner into the TB. I'll check the IAC, though. My son said it looked worn but that once the throttle is opened the IAC should affect the engine's running.
Old 10-24-2006, 02:31 AM
94 4x4 ranger 94 4x4 ranger is offline
Try the fuel pump relay it is under the hood in a black box called the power distrubtion box swap the fuel relay with the A/C relay.
__________________
94 4x4 ranger
Old 10-24-2006, 07:07 AM
I'll check the relay, but unless it is intermittant it wouldn't seem to be the problem. The FP always works at initalization (key "on"). The system is filled with gas at 40psi, but quits when the engine starts up.
It failed all day long Monday, then fired up and ran fine Monday night as we were checking before locking it up for the night.
Go figure!
Old 10-24-2006, 11:51 AM
The relay can cause this.[hr]They do work half ass when going bad
__________________
94 4x4 ranger
Old 10-24-2006, 06:05 PM
Started up again this morning.
On the pump relay: if the relay is intermittant, why would it ALWAYS work when the system is initialized (key turned to "on")? Is there a current load difference when the car tries to run that would cause the relay to malfunction sometimes?
Old 10-25-2006, 12:38 AM
The contacts go bad.
__________________
94 4x4 ranger
Old 10-27-2006, 11:53 AM
After trying everything except changing the fuel pump we accidentally discovered that one of the sets of keys wasn't deactivating the security system. It would allow the doors to be opened and the ignition to be "excited"....but not allow the engine to run.
So far, everything is normal when using the other set of keys.
Go figure!
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
