Temperature Gauge
Old Nov 4, 2006 | 12:41 AM
fordfan419's Avatar
Default Temperature Gauge
The temperature gauge on my 98 Contour is pegged. I have no signs of overheating, coolant levels are good, no telltale smell of overheating. A coworker told me that the problem is likely a bad wiring connection to the gauge or the gauge has failed but not a thermostat issue. Any suggestions?
Old Nov 26, 2006 | 04:59 AM
Aussie Ford's Avatar
Default RE: Temperature Gauge
Bad wiring is a good guess, but it could also be a bad relay or temp sensor. Guages usually are a last resort check.
Old Jun 16, 2007 | 06:57 PM
larryhe's Avatar
There is a TSB about this. TSB 98-21 Oct 3 1998
Old Oct 20, 2007 | 03:04 PM
Gary's Avatar
what does TSB mean? and where can I get a copy. I have a similiar problem except my gauge doesn't move at all.
Please advice.
Old Oct 25, 2007 | 05:03 PM
Gary's Avatar
I looked under Ford TSB for a 1998 Contour and I can not find the below mentioned TSB. Is it located in a different file??
(There is a TSB about this. TSB 98-21 Oct 3 1998)
Old May 17, 2011 | 04:12 PM
Tman24's Avatar
Default temp gauge
I have the same problem on my 98 there are 2 sencers on the thermostat housing 1 or both are bad. one is for the gauge the other is for the computer.
Old May 8, 2015 | 01:28 PM
LADave's Avatar
There are two temperature sensors in the same general area. One runs the temp gauge, the other connects to the computer. Sounds like the gauge sensor is bad, or maybe a wiring issue. If you get one of those OBD-2 scanners that connects to a computer (e.g. laptop), you'll see what the computer sensor is saying about temps. Generally that one seems more accurate.
walnut777
Sep 13, 2009 08:00 PM
nflz32
Dec 30, 2008 03:19 PM
msting
Oct 2, 2007 12:07 PM
mcf
Dec 20, 2006 07:43 PM
Kronos
Jul 13, 2005 07:04 PM
