1990 F150 4x4 302 auto won't idel?
Old Mar 6, 2005 | 10:51 PM
skip's Avatar
Default 1990 F150 4x4 302 auto won't idel?
bought a 1990 f150 4x4 auto 302 ran ok with blowby replaced motor with a remanufactored long block found out it was out of an older car (mid 80's) everything bolted up properly the only diferance i found was the plugs now with the new motor it will run but wont idel? also had trouble tabing the motor and trans if there not meshed right will they bolt together and will it run???
Old Mar 13, 2008 | 10:46 PM
stonemug's Avatar
Default RE: 1990 F150 4x4 302 auto won't idel?
Transmission bolting up shouldn't effect idol of the truck. Check your Idol Air control valve, fuel lines, and fuel pressure. Did you replace the cap, rotor, plugs, and wires?
BIGHOTS
Dec 17, 2012 09:51 AM
eddiedtsr@yahoo.com
Dec 22, 2010 08:10 PM
coojoe
Apr 27, 2008 11:04 PM
ford freindly
Aug 1, 2007 09:27 PM
demonpitbull
Jun 23, 2005 11:02 PM
