2005 brakes
Old Nov 15, 2006 | 10:49 PM
trevgates's Avatar
Default 2005 brakes
Hi everyone, I am having difficulty removing the front rotors on my wifes 2005 escape. I read in the chiltons manual that there is no in depth review on how to remove them so I figured it would be standard procedure as with most brakes (WRONG!!!!!). I removed the nut that I assume holds the rotor on the axle hub and no luck the thing will not budge. I have also noticed that in pictures for the rotor it seems to seperate just before the hub and slips over the axle studs but rotors like this usually have a screw mounting them to the axle hub which I do not see. If anyone can please help or has had similar problems please let me know because I desperately need to get this done and do not want to shell the money out to have a shop do it. Also if I am having this much difficulty with the front rotors are the rears any different? Any and all help is appreciated guys, thanks
Trevor
Old Nov 15, 2006 | 11:22 PM
Default RE: 2005 brakes
If you removed the large nut in the center of the hub, you removed the axle stub nut and doesn't require removal.. The disc is just a 'slip fit' onto the hubs center and over the lug studs as you described.. It may just need a 'bump' to jar it loose.. You might spray some penetrant onto the hub/studs and 'strike' the hub/rotor face to rattle it loose with a brass hammer/drift.. Here's an exploded view of the brake rotor, anchor plate ect...
[IMG]local://upfiles/6756/F5D061B0FA7843809DD890DA6240B1B0.gif[/IMG]
Rears are similar, only a 'drum in hat' ebrake..
[IMG]local://upfiles/6756/7EC1A47222D0434E815102E94F112DDF.gif[/IMG]
Old Nov 16, 2006 | 02:31 AM
wheelsup68's Avatar
Sometimes you need to strike hub face of rotor with big hammer 32oz - 48oz to get these to pop off hub. For future service it would be a good idea to spread antiseize on surface before installing new rotors.
squad272
Mar 5, 2014 01:16 PM
makuloco2000
Sep 19, 2013 11:12 PM
tjc5735
Sep 17, 2013 01:10 AM
sillykidd00
Mar 5, 2012 12:09 PM
oldschool1
North East
47
Jan 13, 2006 04:25 AM
