Universal Joint?
Old Nov 25, 2006 | 03:37 AM
archinth's Avatar
Default Universal Joint?
Just got me a '89 Bronco II. Engine real strong, truck has 166,000 on it. My question is this. When I put the truck into gear (manual tranny), I hear a clicking noise for a moment 'til rpms get upto 3000, then it stops. The clicking noise happens going into 2nd, 3rd, and 4th. I have been told by the seller, that this is the universal joint making the noise. Does this sound right to you guys? Thanks in advance.
Old Dec 15, 2006 | 11:25 PM
COMELECTRIC's Avatar
Default RE: Universal Joint?
if it is a universal joint problem you will hear it mainly in between shifts, (such as when you finally engage second from a 1-2 shift). However, a constant clicking is not usually present. A failed U-joint usually creates a solid clunk between gearshifts. Go underneat the truck and try to rotate the driveshaft (rear) and see if there is any slop. Any motion indicates a worn U-joint.
Hope that helps.
Eric
Old Apr 16, 2007 | 12:05 PM
rapaxis's Avatar
A lot of bronco2's didn't have u-joints, instead they had cv-joints on the driveshaft. If this is your case it could give you those symptoms.
qr3379
May 13, 2012 06:32 PM
ebeck
Jul 31, 2006 10:10 PM
64compact
Nov 2, 2005 08:16 AM
coater
Sep 5, 2005 04:41 AM
DYI
Mar 28, 2005 11:54 PM
