98 Winstar Transmission Slipping?
Old Dec 3, 2006 | 10:34 AM
fivevs's Avatar
Default 98 Winstar Transmission Slipping?
My windstar was running pretty good after taking care of my check engine light ( about a month ago). Yesterday while on the freeway it suddenly sounded as if the engine was revviny up and the vehicle was slowing down.It seems that I had to really push the gas pedal very hard to make the van move. At the same time when I was taking off from a light, it seemed as if it could not go into the overdrive gear. I finally got help and got it pushed for almost 60 miles for fear of ruining the tranny.I sure could use some help from you good folks.
Old Dec 8, 2006 | 12:00 AM
fivevs's Avatar
Default RE: 98 Winstar Transmission Slipping?
OK I know someone out there can help me on this matter. I turn the engine on when cold and the engine seems to run fine , even with the check engine light on. As soon as I put the van in gear, it seems to run fine. When I try to pick up speed it jerks and the engine seems to just rev up and it sounds like a vehicle sounds when it struggles to go into the passing gear. Any ideas? Anyone?
Old Dec 8, 2006 | 12:12 AM
How many miles on the trans? Do you know what the CEL/DTC was from before.. Is there any noise with the slip?
Old Dec 9, 2006 | 02:01 AM
fivevs's Avatar
About 130k. The cel before was due to #4 cylinder misfire. I cleaned out the fuel injectors and swapped two of them to make sure the one which came from 4 was not bad. Replaced the upper intake gaskets. Also replaced thermostat as well as temperature sensors. The noise it makes is like a loud winding noise.
This cleared up the cel long enough to get it inspected legally.
Old Dec 30, 2006 | 06:31 AM
Rockinwindstar's Avatar
Try changing the fluid, if its low, or burnt it could cause sliping, if not there are a few other things like the torqe converter...
Old Jul 9, 2007 | 07:38 PM
lfish1's Avatar
my 98 windstar began suddenly downshifting at highway speed. Replacing the transmissionneutral safety switch solved my problem. It does more than prevent starting in gear.
Old Feb 17, 2009 | 07:56 PM
taxer's Avatar
Was the tranny slipping out of OD? My 99 won't go into OD anymore. Everything else is fine.
btbell0615
Sep 16, 2012 05:27 PM
Mattlock
Jul 4, 2011 07:08 AM
mightybg
Apr 29, 2010 11:44 AM
cougsangel
May 9, 2009 01:17 PM
shooked
Apr 25, 2007 06:37 AM
