2000 Front Brake Rotors
Old Dec 13, 2006 | 03:18 AM
Lawdawg425's Avatar
Default 2000 Front Brake Rotors
1st what brand of T-40 bit do you use to remove the front rotors? (Have broke 2 bits all ready) and do you have to re-install the hex bolts for the rotors? The hex bolts seem to be really seized on there or any suggestion on what to use to loosen the bolts.
Thanks,
Justin
Old Dec 17, 2006 | 06:40 AM
Malibu Barbie's Avatar
Default RE: 2000 Front Brake Rotors
The only drill bits I've had luck with, and trust, are Sear's Craftsman. When removingbroken bolts/studs, the key is to use a small drill bit, then keep going wider until you're able to pull the bolt out with your hand.NEVERlet the drill bit make contact with the outer edges of the bolt/stud.
Here'sa link that provides this method, as well as others (excellent article): http://www.asashop.org/autoinc/may2003/techtotech.cfm.
Old Dec 17, 2006 | 03:51 PM
wheelsup68's Avatar
Don't remember ever seeing retaining bolts for rotors on windstar? However if it does have these bolts they need to be removed with an impact driver. Impact drives are special tools that allow you to strike a hammer against driver and it provides a blast of inward twisting power to remove thes small screws/bolts
tajandzane
Oct 10, 2009 05:36 AM
tajandzane
Oct 5, 2009 06:44 PM
retiredlarry
Dec 18, 2006 05:45 PM
97xj4.0
Sep 18, 2005 09:47 PM
Natedogg
Aug 21, 2005 11:09 PM
