engine runs rough and stalls
Old Mar 21, 2005 | 11:35 PM
Loum12's Avatar
Default engine runs rough and stalls
Hello to all:
I have a 1993 ford f-150 4x4 5.0. I recently installed new plugs (motor craft), new cap, new wires. All of a sudden the truck starts and stalls right away. It run rough and the idle moves up and down. I checked for crossed wires and I brought it up on tdc and checked distributor postition as to # 1 position. I checked for vacuum leaks, the check engine light come on and goes off. I have sprayed starting fluid looking for vacuum leaks. I am at my wits end. when I am driving the engine changes rpm's. Any thoughts
Lou
Old Mar 22, 2005 | 06:50 PM
Patrick's Avatar
Administrator
Default RE: engine runs rough and stalls
try a new dist cap...sounds like the one you got may be cracked..try putting the old stuf back on and see if it goes away. it sounds to me like a dist cap issue...
Old Mar 23, 2005 | 06:15 PM
Check the codes and trouble shoot from there, I think you may have accidently unplug a connector. It sounds more like an air/fuel problem
Old Mar 28, 2005 | 11:43 PM
94Flare's Avatar
If you look in a chilton or motor manual, or if your lucky enough to still have the decal under the hood, it shows the EXACT way the wires are to be routed with regards to which ones are routed on top and under each other. I can tell you from my own experience that if they are not routed in this manner that you can actually have a serious misfire situation.
Screenwriter
Dec 8, 2016 08:37 PM
chad_allen123
Apr 1, 2014 08:37 PM
a_frenchswallow
Sep 27, 2010 07:53 AM
louchris
Nov 29, 2007 11:58 AM
