Brakes and Cruise control
Old Dec 20, 2006 | 12:13 PM
s0981's Avatar
Default Brakes and Cruise control
I recently had to change the brakes on my 2005 (27,000mi) and now my cruise control is working off and on. I suspect it has something to do with the brakes because when the cruise willnot work if I tap the brakes and push the cruise button it will come on for a second but, then turn off right away. Other times it will work for a few minutes but then just stop. Any help would be greatly appreciated
Old Feb 4, 2007 | 03:05 AM
1954ford's Avatar
Default RE: Brakes and Cruise control
your cruise should shut off when the brake pedal is beeing applied, it's a safety feature built into the cruse system, as far as the other times it cuts out what is it doing exactly, are you accidentally pressing the brake pedal? are anybrake light bulbs burned out? burned out bulbs can make the sysem inop, also doe your horn work and does your air bag light stay on or flash, these could indicate a broken/breaking clock spring, also might want to check the wheel speed sensors for damage when the brakes were serviced.
jski1974
Dec 3, 2010 12:21 AM
shadybiz11
May 19, 2008 12:58 PM
gweedo
Nov 21, 2007 05:42 PM
AP
Jul 28, 2007 03:01 PM
93f250xlt4x4
Sep 3, 2006 09:59 PM
