AOD valve body
Old Dec 24, 2006 | 03:55 PM
boss68's Avatar
Default AOD valve body
Ok techguys i need some info!
1981 Lincoln AOD. Worked PERFECT then i changed the fluid. Have been through a number of additives and partial changes and now have the most expensive fluid a 1981 Lincoln has ever had!
Several recomendations but none have cured the slip bump and questionable overdrive shift that the new fluid has left me with. I cannot re-use the old fluid as it was drained into a contaminated container.
At this point a replacement or modification of the valve body looks to be the only way to deal with this problem. I have gone through the valve body and found no problems with it.
My questions are, i have heard that the newer valve bodys (late 1980s) are improved in the way the tolerate fluids and need to know if a direct swap can be made from a later VB to this trans?
Also, i have heard that Ford sells a new VB for these AODs that incorporates all the updates and improvements.
Also, would this trans need thereplacement VB from a lincoln to maintain thecallibration or are all the VBs callibrated the same?
By the way, i am a former Ford employee and ASE Certified Mechanic.No problem fixing it, i just need to know the solution.
Many thanks to any one who can fill me in on this info!
DrakeOmancer
Jun 4, 2015 07:00 AM
makuloco2000
Aug 19, 2014 11:20 AM
jenmes70
Jul 29, 2013 07:17 PM
gstadter
Apr 10, 2011 02:52 PM
WV-F150-4.2L
Mar 16, 2011 06:34 PM
