Putting bigger tires on
Old Mar 24, 2005 | 06:42 AM
astrapous's Avatar
Default Putting bigger tires on
I have a 1997 F150 I just recently bought, and I want to put 33" tires on it. One of my friends told me that I don't need to lift the truck to put 33" tires on it. Is that true? If not I don't have alot of money could someone recommend me a good lift for the money. Thank you.
Old Mar 24, 2005 | 11:44 AM
95f150kid's Avatar
Default RE: Putting bigger tires on
33's fit on a stock dodge from the factory so i dont see why they wont fit on the ford but if u do need a lift and are on a low buget then get a rough country they are cheap and good
Old Mar 24, 2005 | 03:23 PM
Patrick's Avatar
Administrator
what is the factory tire size on your truck now, and how much clearance do you have from the top of your tire, to the edge of the fender? once you measure that, and give me your current tire size, i can give you more advice on how much bigger you can go...but keep in mind, if you go bigger and wider, you may have issues when turning...the way you check for this is to cut your wheel all the way to each side, and measure how close the tire is to the inner fender lining on both tires. then take into consideration how much wider the bigger tire will be.
Old Mar 24, 2005 | 06:44 PM
astrapous's Avatar
from the ground to the to of the wheel wall is 33", and the width of the wheel wall is 36". I believe the tires on them currenctly 27" tires. Is that enough info?
Old Mar 25, 2005 | 03:24 PM
Patrick's Avatar
Administrator
hmm....i dont think i made sense in the first post...i need the tire size like 245-50-15..so on...then measure from the top of the tire, nearest the fender, to the bottom edge of the fender?
Old Sep 18, 2005 | 12:53 PM
maineman's Avatar
i have a 97 ex cab that has 32's on it and i have no probs.
Old Dec 21, 2008 | 10:02 PM
builttough15_'s Avatar
on suspensionconnection.com,they have a 3" body lift for $212. i dont know if that is out of your price range but it would allow you to put your 33's on and you should have no problems.
Old Dec 22, 2008 | 10:13 PM
sl33p3r's Avatar
it should fit with no problem.[sm=smiley2.gif]
jasper
Feb 22, 2007 11:49 PM
rykno44
Aug 6, 2006 11:33 PM
l00py1211
Oct 19, 2005 04:56 AM
WildChild
May 22, 2005 11:53 AM
WildChild
Feb 3, 2005 01:08 PM
