Shock Replacement
Old Jan 2, 2007 | 11:11 AM
tnfritch's Avatar
Default Shock Replacement
It looks like I will be replacing my factory shocks on my 98 F-150. I was curious if anyone could recommend a good set of shocks that matched my stock shocks pretty closely(without actually ordering factory Ford replacement shocks). Thanks for any input.
Old Jan 2, 2007 | 10:57 PM
wheelsup68's Avatar
Default RE: Shock Replacement
Anything aftermarket will outlive/outperform your OE shocks. The best on the market right now are the Monroe Reflex shocks and they are costly. You will pay about $35-$45 a piece for them, but they are well worth it.
Old Jan 3, 2007 | 12:12 AM
Capt.Moe's Avatar
I am not a fan of the Monroe, Look to pay a little more for a nice set of Bilstiens. They are a kick *** shock for most anything you do.
Old Jan 4, 2007 | 10:03 PM
tnfritch's Avatar
Do you know if the Monroe Sensa trac shocks are any good?
Old Jan 5, 2007 | 02:01 AM
wheelsup68's Avatar
I install a bunch of sensa a tracs, and they are good for the money, but what makes the reflex so much better is the vavlving is controlled by a spring sensative actuator at bottom of shock that reacts much wuicker to road conditions.
Old Jan 11, 2007 | 10:23 PM
tnfritch's Avatar
Thanks for the advice. I just received the reflex shocks today in the mail. Any good advice on installing them?
Old Jan 11, 2007 | 11:57 PM
wheelsup68's Avatar
There are really no big tricks to installing them. I gues the simplest thing I can advise is to not unload the suspension when replacing. When doing back Jack up on differential and leave pressure there don't let it down on the jack stands.
Old Jan 20, 2007 | 12:06 PM
tnfritch's Avatar
One I got my Monroe Reflex shocks, one othe shocks came with hardware that two nuts while the other one had one nut? So which is it? I figured on the bottom side of the top mount that I should have the rubber bushing and washer. And on the top side of of the top mount that I should have a bushing, washer, and nut?
Old Jan 21, 2007 | 12:05 AM
wheelsup68's Avatar
Okay, here you go from bottom to top it goes washer, bushing, through hole, bushing, washer, nut. Your extra nut is probably just a jam nut and is not really necessary.
Willard
Mar 30, 2009 11:17 AM
RH2OMAN
Jun 13, 2007 02:15 PM
rustbucket89
Dec 3, 2006 11:53 PM
pannwfn
Apr 10, 2006 03:07 PM
Tony_8
Mar 17, 2006 05:08 PM
