83 bronco w/EFI won't start
Old Jan 14, 2007 | 08:54 PM
reinholdt's Avatar
Default 83 bronco w/EFI won't start
83 ford bronco, 4.9 liter, EFI, AutoTrans. Replaced plugs, wires, cap, rotor and battery. 40 psi fuel pressure at fuel rail. Good spark to all plugs, Injectors are being pulsed and all test good - engine will not start nornally. I have to use a shot of starting fluid to get it going - then I can start and stop it with no problem - it starts right up normally. When I let the car stand for several hours the problem is back. Engine turns over fine and fuel pressure is 40 psi - but no start. I have replaced the air bypass valve but this had no effect - I really don't know what to do next. Any suggestions would be very much appreciated.
Old Jan 15, 2007 | 04:17 PM
94 4x4 ranger's Avatar
Default RE: 83 bronco w/EFI won't start
Get a fuel sample to see if it is contaminated with water.Also repalace the fuel pump relay.
Jxster
Mar 27, 2014 03:17 AM
clman
Nov 16, 2012 12:47 PM
Powder Blue
Central
Jun 4, 2010 11:38 PM
mikeydee123
Jan 5, 2010 09:58 AM
noonrock
Jan 13, 2009 09:00 AM
