transmission fluid/filter change
Old Jan 16, 2007 | 09:19 PM
elementx440's Avatar
Default transmission fluid/filter change
So I was going to change the fluid/filter, but as I started reading about, some people were advising against it on higher mileage cars. They said the detergents in the new fluid may clean out some deposits and possibly cause leaks/failures.
I have a 2000 Focus w/ 105k miles, and a 2001 ZX2 with 42k miles. What do you think?
Old Jan 23, 2007 | 11:34 PM
Default RE: transmission fluid/filter change
you guys are worthless.
Old Jan 23, 2007 | 11:50 PM
wheelsup68's Avatar
Go for it. I would rec'd doing a flush though instead of replacing just your filter and pan gasket. Use a good fluid like the valvoline max life atf, it will help prevent some leaks with it's additives. Flush will get out closer to 95% whereas filter and gasket will do like 35-40%
makuloco2000
Aug 24, 2014 07:50 PM
mikegigabyte
Feb 28, 2008 10:36 PM
dee004
May 8, 2007 08:04 PM
mmahonzy
May 19, 2006 01:12 AM
mossimo817
May 10, 2006 05:47 PM
