front end thumping when i hit bumps..help
Old Feb 7, 2007 | 03:57 PM
chachi's Avatar
Default front end thumping when i hit bumps..help
I have a 03 escape limited...when i hit bumps the front end makes a thumping sound....my friend who is a mechanic looked it over and thinks it is the subframe mounts....he lifted the car and said the rear of the subframe dropped...i called the dealership and they said there is no mount and that the subframe is hard bolted to the unitbody....has anyone had this problem?? any diagram?? repair advise? All input appreciated.................Chachi
Old Feb 25, 2007 | 11:15 AM
freez401's Avatar
Default RE: front end thumping when i hit bumps..help
Same problem here, my wife has a 2002 escape and when she goes over a bump there isa thump in the front end...??
Old Aug 26, 2007 | 12:34 PM
nicroley's Avatar
it's the bushings...have them repacked that should help. I hadthe same issue when I got my 2002 used and it was the bushings and after they are fixed try to take it easy on the speed bumps!
Old Aug 27, 2007 | 08:23 AM
surfscape's Avatar
Usually the first thing to go is the stabalizer bar links and or mount busings. Then the ball joints. If you lift the car and push on the various components you will see looseness (paly) on the worn parts.
Old Aug 30, 2007 | 09:38 PM
lv2escape's Avatar
Don't know if it's the same, but I have a 2002 Escape with 125k miles and it has had a loud popping noise in the front suspension for almost a year and no one could properly diagnose it. Turned out to be a bad/worn outstabilizer bar. My mechanic replaced it for a whopping $40.00 parts and labor. So it was well worththe small price to pay,and the sound is finally gone.
Old May 3, 2008 | 07:30 PM
daskivt1679@aol.com's Avatar
had same on one side,,,stabilizer bar links,they run from lower to upper susp.parts tying them together, 25$ a piece,100$ job.replace both at same time
Old Sep 15, 2008 | 08:47 PM
hefty's Avatar
We had the same problem. The dealer replaced the stabilizer bars which did not fix the clunk. My husband put in a new stabilizer bar and this took care of the problem.
Old Sep 15, 2008 | 08:48 PM
hefty's Avatar
i meant my husband replaced the tie rod.
makuloco2000
Nov 6, 2014 01:13 PM
Roadwarrior
Apr 15, 2014 07:35 AM
formerflyboy
Dec 3, 2011 04:00 PM
ngaspecialties
Sep 25, 2009 07:46 PM
stamour46
Jan 22, 2006 05:18 PM
