REAR END NOISE(BAD) IN EXPEDITION 2003
Old Apr 22, 2004 | 11:34 PM
POOPSHOOTER's Avatar
Default REAR END NOISE(BAD) IN EXPEDITION 2003
ANYONE HAVING REAR END NOISE, RING AND PINION. DEALER AND FORD TELLS ME IT IS KNOWN PROBLEM IN EXPLORER, CROWN VICTORIA AND EXPEDITION. NO FIX CURRENTLY AVAILABLE.
Old Dec 11, 2004 | 01:01 AM
corzolek's Avatar
Default RE: REAR END NOISE(BAD) IN EXPEDITION 2003
I have an 03. Mine made some noise but was also causing vibration in turns when it was cold. The garage finally found it was a bad set of clutches in the limited slip rear. If you have this rear that is probably your problem.
Old Sep 3, 2005 | 12:47 PM
sjordan007's Avatar
Had same thing on my '03. had it fixed at 28,000Mi. seems a little early for rearend problems huh...
Old Sep 3, 2005 | 05:47 PM
Better find you a new DEALER , look at the top of the Forum screen , you see the lil sub sections one says FORD TSB, click on that an look up your vechile , YES FORD HAS A PROBLEM WITH THIS !!!! ,An sometimes they gotta replace the entire rear end assy !!! So your DEALER IS FULL OF ---- [sm=bs.gif],,,, Print out the TSB an take it back to him. !!!!!!
Old Sep 3, 2005 | 09:21 PM
Sabretooth's Avatar
Ahh, I've come to the realization that the only noise worth fixing on my truck is the one I can't drown out w/ my radio...mind you it's a 91...anyways, good advice Ramrod, the rear-ends are notoriously bad on some of the newer trucks and rwd cars...don't know why, but I think they've fixed the problem on the newer models...ah well, good old recalls...
Old Sep 4, 2005 | 01:30 AM
http://www-odi.nhtsa.dot.gov/cars/problems/tsb/,,, also theres A phone # there file a complaint , theres pleanty otheres that have !!!!!
Old Sep 26, 2005 | 12:32 AM
marcelotx6's Avatar
I have a 2003 Eddie Bauer. The first time I've heard the noise was at 500 miles. They replaced the clutch kit. Then repeated at 25000 miles, and replaced clutch 2nd time, and, guess what? AGAIN at 42000 miles (out of 36000 mi. warranty). This time, before going to the dealer, I asked for REPURCHASE, running the Lemmon Law. But, the law requires to give an opportunity to the manufacturer to repair the vehicle (the 3rd time), as if two is not enough. I did, and now I'm waiting for the next time to finally give this too-poor-quality-vehicle back, and NEVER buy a Ford again
jefftx
Oct 7, 2012 08:04 PM
rlpatte
Mar 31, 2012 08:45 PM
knutsoncust
Feb 2, 2009 02:17 PM
rugger_6
May 20, 2008 10:45 AM
wpgbronco
Nov 27, 2005 02:21 PM
