will this cam lope
Old Feb 10, 2007 | 11:42 PM
302rocker's Avatar
Default will this cam lope
i was looking at this cam i was wondring if it would be noticeable at idle >thanks
Cam Style:
Hydraulic flat tappet
Basic Operating RPM Range:
2,000-4,500 RPM
Intake Duration at 050 inch Lift:
218
Exhaust Duration at 050 inch Lift:
228
218 int./228 exh.
Advertised Intake Duration:
276
Advertised Exhaust Duration:
286
Advertised Duration:
276 int./286 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:
0.471 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:
0.471 in.
0.471 int./0.471 exh. lift
Lobe Separation (degrees):
114
sexyxxxrebelxxx
Jun 12, 2010 02:58 PM
302rocker
Feb 10, 2007 11:12 PM
Teunekid
Nov 23, 2005 10:00 AM
Aussie Explorer 98
Nov 13, 2005 02:19 PM
bingermann
Oct 31, 2005 01:36 PM
