C4 trans
Old Apr 23, 2004 | 07:01 AM
Ranger's Avatar
Default C4 trans
Drive a 1979 ford ranger (F150) with a 302.
(Limited slip).Istead of the C4 trans i have now,should i go with the C6?
Old Apr 26, 2004 | 02:48 PM
roundman's Avatar
Default RE: C4 trans
no real need to switch up to a C-6 unless you have highly modified the 302 to put out over 300+ HP, the C-4 is fine for what the stock motor can do and it is lighter than a C-6 also.
Old Jul 23, 2012 | 07:47 PM
bandit1948's Avatar
the c-6 won,t bolt up to your 302 ! the 302 is a small block and the c-6 transmission is made for a big block ! did you think about putting a shift kit in the c-4 ? a shift kit will make the transmission shift quicker !
Old Jul 23, 2012 | 08:29 PM
grindman's Avatar
I had a 77 F150 that had a 4.9 or 300 c.i.d. in it with a c6 tranny behind it and we all know that a 300 and a 302 has the same bolt pattern on the hogs head.
conanalois
Aug 31, 2013 06:16 AM
xkikbxr
Oct 22, 2004 03:15 PM
mudjnky
Aug 3, 2004 11:22 PM
NOS/MAN
Apr 20, 2004 01:42 PM
mrwhipper
Apr 18, 2004 09:33 AM
