1995 Explorer need help
Old Apr 9, 2005 | 02:21 PM
egghead335's Avatar
Default 1995 Explorer need help
i have a 1995 ford explorer and both rear doors will not open from the inside and the child lock is off. im wondering if any one esle has had or dose have this problem and if they know how to fix it ?
also for the drivers seat u cant roll down the rear windows but i can roll them up is that a wireing problem ?
The windshield wipers only work on the high setting can that be fixed?
my email is egghead335@hotmail. com
and i have instant messanger to thats egghead335
Old Apr 11, 2005 | 03:08 PM
Default RE: 1995 Explorer need help
Ok, suspect the rear door shafts to the latch has come off, or that the handles are broken. Take the covers off and check for this, look for the plastic peice that keeps it on and replace if needed. Don't forget to lube
The switch at the drivers door most be bad, when this happens thow its usually the drivers door window that stops working. So this maybe an easy fix. Carefully remove the switch from the door and disconnect it. Then just try cleaning it with electrictronic cleaner, if your brave disassemble it and clean. Sometime dirt and soda get in them
The wipers, again its the switch, does your turnsignals sometimes not work or windshield washer not spray? This switch is a little more complicated then the one on the door. Its about 100$ at autozone and not that hard to install
Old May 22, 2007 | 02:00 PM
mstrat140's Avatar
try replacing fuses
Old May 14, 2014 | 01:39 PM
logsdonjim's Avatar
Default Windows
My 4WD and 4WD lights will blink intermittently and my windows will stop working. I drive a while and the lights will quit blinking and my power windows will work. What is the problem and id there a fix.
RSinger
Sep 14, 2014 11:50 PM
gaigejohn
Oct 2, 2011 03:10 AM
jeremy512
Sep 20, 2010 08:16 AM
Horvik
Oct 2, 2009 03:45 PM
gbooker83
Oct 6, 2008 07:27 PM
