Closed Loop fuel control
Old Feb 27, 2007 | 07:10 PM
Bearhunter's Avatar
Default Closed Loop fuel control
My check engine light has come on and the code came back Insufficient Coolant temp. Everything seems ok, heats up good holds temp steady May be down on gas mileage a little. Any Ideas or help greatly appreciated.
Old Feb 27, 2007 | 07:16 PM
Default RE: Closed Loop fuel control
Are you able to read Data/PID temps?
Old Feb 27, 2007 | 07:18 PM
Bearhunter's Avatar
No I am not
Old Feb 28, 2007 | 10:16 PM
way2old's Avatar
If the code was a P0125, the thermostat is stuck partially open and taking too long for the engine to warm up to place the system intoclosed loop. Change thermostat and clear the code. It should be OK.
phisherman
Apr 11, 2016 12:11 PM
rmorse
Jan 18, 2009 09:49 PM
4x4firefighter
May 21, 2008 01:54 PM
BluProbeGT
May 31, 2007 03:37 PM
truebob
Feb 11, 2006 04:11 PM
