F-250 7,3 TD Where do i let the air out of the fuelsystem?
Old Mar 30, 2007 | 12:24 PM
paddish's Avatar
Default F-250 7,3 TD Where do i let the air out of the fuelsystem?
I have a 2000 model F-250 7,3 Turbo Diesel and I accidently managed to empty my fuel-tank,
thanks to misleading fuel-gauge
And now of course I wonder where do I air out the system and please, can somebody maybe reply
with a picture unless it is very easy to do it?
Thanks!
/Patrik
Old Mar 30, 2007 | 01:49 PM
Default RE: F-250 7,3 TD Where do i let the air out of the fuelsystem?
The 7.3 has a 'return to tank' system and doesn't, or shouldn't require any purging.. On a empty tank you should be able to cycle the key a few extended times and fuel should be circulated through out the system.. If any air is in the head/fuel rail it will purge on its own with some run time..
Old Mar 30, 2007 | 06:40 PM
Most all systems ever made work the same - self bleeding.
Old Apr 2, 2007 | 01:36 PM
DoUgLaS's Avatar
on my 92 F250 which has theinternational 7.3 there is a bleeder valve (much like a valve stem) right by the feul filter.
Old Apr 2, 2007 | 02:58 PM
Non PSD is altogether different....
Old Apr 2, 2007 | 06:37 PM
Any system that opens for intake normally, without the presence of fuel will bleed itself. Most do - I'm sure not all. Some mayuse a signal switch indicating fuel presence before allowing flow from the fuel system. Either way you look at it though anything but normal is a big pain in the butt.
Old Apr 2, 2007 | 08:12 PM
A schraeder valve isn't really a bleeder valve - right?
Old Jul 24, 2007 | 07:45 AM
dieselman21585's Avatar
The Schraeder valve on the old 7.3 IDI is an air escape. As for the PSD, I would utilize the water drain to release air.
d1badz
Dec 15, 2008 04:48 PM
SAMF
Oct 4, 2008 10:07 PM
Mid West
11
Feb 3, 2008 08:46 AM
AndrewMacks4.0
Oct 21, 2006 11:09 PM
CobieCane
Sep 7, 2005 02:08 AM
