removing stock radio
Old Mar 31, 2007 | 03:31 PM
317th's Avatar
Default removing stock radio
anyone know how to remove the radio? i want to install a amp to enrich the sound and add a sub... i dident get the audiophile package so i dont have the 6x9s in the rear deck.... and all the speaker wires are run through the frame... im not sure wear to begin to take apart the door panels....any help would be appreciated.
Old Apr 1, 2007 | 07:19 PM
Default RE: removing stock radio
First - door panels have screws and fasteners - under armrests, in panel carpeting, under plastic caps, etc. that must be removed first. Then there are clips attaching it also. The radio may be easier to access from under the dash on the driver or passenger sides. Removing a stock radio might necessitate having a removal tool or knowing how the latches or attaching hardware hold it in. If you take a small inspection mirror and look in the back you may be able to figure how the latch works.
tombssebastian
Dec 12, 2008 10:10 PM
NITROUSMIKEY
Jan 27, 2008 10:12 PM
gtcoatie
Jan 25, 2007 07:52 PM
luv2icefish
Jan 8, 2007 10:46 PM
jgorz420
Apr 16, 2006 05:13 PM
