Torque converter plug?
Old Apr 1, 2007 | 04:38 PM
gearyoil's Avatar
Default Torque converter plug?
Does anybody know if my 2000 Focus wagon has a drain plug on the torque converter. I plan to drop the pan and change the filter instead of having it "pumped". Thanks.
Old Apr 1, 2007 | 09:33 PM
Default RE: Torque converter plug?
Most converters haven't had drain plugs since the 60's/70's. If it does it would be on the side facing the engine and you could access it through the starter hole but you would need a bottom plate removed to drain it right ( or a hole in the bottom of the block plate) or else you'd have a mess.
Old Apr 1, 2007 | 09:35 PM
You can drain some more by cranking the engine (not starting).
oleblue64
Nov 23, 2017 09:11 PM
crash702
Oct 26, 2008 06:45 PM
whitall
Jul 20, 2007 11:54 AM
railboy36
Jul 16, 2007 06:39 PM
railboy36
