system cut out
Old Apr 2, 2007 | 04:29 AM
shagwagon's Avatar
Default system cut out
ok well heres what i have
Power Acoustik fubr 12s
Power Acoustik 1400 watt Plasma Sphere amp
Power Acoustik cd player
I ahve the sub ran mono to the amp.......heres my problem when i turn the volum up pretty loud the amp will cut off and if i just turn the cd player on and off the amp will kich back in. now when i have the bass turned up it will cut out sooner then if i had the remote turned down. The system will still pound hard but when it just gets to a point it will cut out.any help would be great.
Old Apr 2, 2007 | 09:04 PM
Default RE: system cut out
Sounds like you're pumping too many watts into the amp. How much input can it handle? You may need RCA in adapters.
Old Apr 3, 2007 | 03:53 AM
shagwagon's Avatar
how can i find out how much input it can handle?
Old Apr 4, 2007 | 02:50 AM
If it has RCA-ins it has a standard amount. I think the inputs are rather low for RCAs. Like 50 Watt total? (That's just a guess though).
Old Apr 4, 2007 | 04:43 AM
shagwagon's Avatar
it has rca ins
Old Apr 4, 2007 | 05:20 PM
If the amp has RCA ins and your CD player has regular outs you'll need RCA converters to change it to RCA output or at high power it'll clip. Also speaker phasing is important.
Old Jul 9, 2007 | 03:58 PM
ky_ace's Avatar
It sounds to me like your amp is killing your battery's reserve. You should definitely look into getting a cap for that system. I would suggest 1 farad for every 1000 amps of power. So you would probably want a 1.5 or a 2 farad cap. You should be able to pick one up for $75-$150. It keeps 12+ volts in reserve and keeps the amp from running short on power. If you were overloading the amp, it would blow a fuse and wouldn't cut in and out. I think you're overloading the vehicle electronics. If you used a standard wiring kit, you should be running only 50x4 max to the amp.
Just my .o2
BM
Old Mar 5, 2008 | 09:33 PM
grease_monkey1965's Avatar
i had the same problem in my mustang, at night when i was driving my lights would dim every time the bass hit ,added a couple of capaciters problem cured
Benkiller
Sep 26, 2013 06:49 AM
Sgtguerra
Sep 12, 2013 11:45 AM
ac917x
Jan 15, 2012 06:12 PM
Bbarrier1
Jun 17, 2011 06:10 PM
artcat99zl
May 4, 2011 11:54 AM
