'96 Ford Ranger Wiper Problem
Old Apr 26, 2005 | 07:07 PM
Danzig's Avatar
Default '96 Ford Ranger Wiper Problem
I recently purchased a 96 Ranger XLT 4 Cyl Manual, only paid 2400, only has 95,000 miles on it. Unfortunately the wipers don't work. I have done everything but blow the truck up to fix it. I have replaced both the motor and the multi function switch, i have taken a test light to the fuse box, the relay box and the motor plug, all tested positive. I used a volt meter and found that the plug is recieving and 12 volts required to turn the motor, yet the motor does not function, I am positively at a loss at what to try next, any ideas?
Old Apr 28, 2005 | 07:42 PM
Default RE: '96 Ford Ranger Wiper Problem
Might not be getting a good ground. connect the test light to the b+ of battery and test the body of the wiper motor, then the connector for the ground wire. good luck
Old Jul 23, 2017 | 08:29 AM
Rob252's Avatar
my son inlaw had a wiper problem that ended up being the ignition switch. Also i think the wipers have a relay under the hood.
Old Jul 23, 2017 | 09:10 AM
I have question that is kinda of puzzling,
If all the other functions that depend on the ignition switch for sufficient power and function worked properly, how did the switch differentiate between those systems and the wiper system ? Could it be the power to the wipers was insufficient due to a poor connection at the fuse or the motor itself?
Wegle1
Aug 23, 2012 07:14 PM
roreru
Dec 10, 2010 02:06 PM
Guillaume_8667
Aug 29, 2009 10:42 PM
emsdad
Apr 17, 2008 10:10 AM
rangerlynn
Sep 20, 2007 06:42 PM
