Removing the tailgate glass
Old Apr 26, 2005 | 11:38 PM
newby30's Avatar
Default Removing the tailgate glass
Anyone know how to go about this in a 92 fullsize?
Old Jun 26, 2005 | 07:37 PM
93bronco's Avatar
Default RE: Removing the tailgate glass
Lower the tailgate and remove the access panel. raise the window with either a jumper wire to the motor or manually. then you should see some nuts going through the window holding it to the regulator arm. before you remove the window make sure to remove the defroster leads if it has rear defrost.
MaryAnne Rosetti
Oct 20, 2012 07:41 AM
mattcw31
Feb 14, 2009 04:03 PM
cctxfish
Apr 20, 2006 12:41 AM
djole_u2
Sep 25, 2005 10:31 AM
Autogeek
Aug 9, 2005 01:16 PM
