how do i remove the front rotor from my 84 bronco
Old May 1, 2007 | 11:49 PM
crashxnxburn's Avatar
Default how do i remove the front rotor from my 84 bronco
cant get the rotor off please help, thanks
Old May 5, 2007 | 02:37 AM
rustbucket89's Avatar
Default RE: how do i remove the front rotor from my 84 bronco
first off i need to know if it is 4wheel drive..if so you have to pull the hub apart and get to the nut that holds the hub assembly and rotor to the spindle..you may need a special tool to remove the nut but it may be done with a screwdriver and a little patients.
patioman
Dec 6, 2007 09:45 AM
retiredlarry
Oct 24, 2007 01:02 PM
crashxnxburn
May 1, 2007 11:47 PM
DoctorAuto
May 23, 2006 09:32 PM
DoctorAuto
May 20, 2006 09:23 PM
