bronco will not go up a long hill
Old Apr 30, 2005 | 02:37 PM
dennis1234's Avatar
Default bronco will not go up a long hill
i have 87 bronco 2 that will not go up a long hill without starting to backfire and lose power. it runs like new around town . it also seems to crap out after a long drive or very hard exceleration. i have had it scoped on a machine for defective sensors but nothing shows up. i changed dist cap . plug wires. rotar.the fuel pump on the frame and in the tank and almost every sensor we can think of. the stange thing is that it will run like new around the city. unless you reallyput the pedal down hard for a long period of time. we have spent a lot of time and money triying to figure this out. it seemed to have helped a bit by changeing the dist cap and rotar .but will not make it up along hill . could it be a coil problem . i sure would apreciate any input. thank u.
Old Apr 30, 2005 | 06:28 PM
solo_one's Avatar
Default RE: bronco will not go up a long hill
Its a long shot, but have you checked the catalytic converter? It could be partially plugged.
Old May 6, 2005 | 08:02 AM
Ticky's Avatar
dodgy fuel filter my friend ive seen it before and if ya replaced it, it could be around the wrong way good luck digger
Old May 6, 2005 | 03:57 PM
Test the MAP sensor
Old Oct 19, 2005 | 10:37 PM
rusty ol ranger's Avatar
It sounds like its loading up with gas.
I would look at the FPR.
later,
Dustin
Cfgunnell
Jan 15, 2013 10:15 AM
Ctwngrl07
Jun 19, 2012 06:16 PM
readcit
Dec 12, 2010 11:27 AM
Stangman
Aug 15, 2009 08:42 PM
NSchrock
Sep 29, 2005 04:17 AM
