Heating-A/C vacuum system
Old Jun 2, 2007 | 06:38 PM
fthoffman's Avatar
Default Heating-A/C vacuum system
does anyone know where I can find the interior schematics for the Heating and A/C vacuum system for my 2002 E350?
Old Jun 2, 2007 | 07:14 PM
Default RE: Heating-A/C vacuum system
See if this helps
[IMG]local://upfiles/6756/A2761B4991214436827509A0A338F6F9.gif[/IMG]
Item
Part Number
Description
Vacuum to the auxiliary A/C system (if equipped)
18A318
Vacuum control motor — floor/panel door
Panel vent airflow
Floor/panel door (full vacuum position) (part of 18471)
18B545
Temperature blend door (full heat position)
Evaporator core
19A813
Air inlet door (full vacuum position)
8
Outside air inlet
9
18A318
Vacuum control motor — air inlet duct door
10
Recirculated air inlet
11
19805
Blower motor
12
18476
Heater core
13
Vacuum from the engine intake manifold
14
19A563
A/C vacuum check valve
15
19A566
A/C vacuum reservoir tank and bracket
16
19B888
Function selector switch
17
Floor air flow
18
18A318
Vacuum control motor — floor/defrost door
19
Floor/defrost door (full vacuum position) (part of 18471)
20
Defrost airflow
Old Aug 22, 2010 | 11:24 PM
rd7scoop's Avatar
Question Parts Location HVAC Vacuum Motor - defrost/plenum
Working on 1994 E150 HVAC.
WHERE is the Vacuum Motor located (how can I get to it to replace it) which controls the flow of air to the defrost vents vs the panel vents (plenum)?
This appears to be a common problem for several years and models: after several seconds of low vacuum (hard acceleration), the A/C system switches from cold air coming through the Panel vents, to hot air coming from the Defroster vents.
I think the part number is 18A318, but I have looked in two sets of manuals and cannot find the location (and what else to remove) of the Defrost/Plenum Vacuum Motor. HELP
Old Aug 23, 2010 | 12:55 PM
stuart40ca's Avatar
You should start your own thread.
wmshep48
May 23, 2010 01:59 PM
Thacashstream
Dec 10, 2009 05:55 PM
ricbelley
Oct 21, 2008 08:46 PM
duckdaddy
Mar 30, 2008 02:32 PM
jeffandteneka
Feb 16, 2007 09:58 AM
