Ignition Problems
Old May 4, 2005 | 09:17 AM
84 SC's Avatar
Default Ignition Problems
I have an ignition problem in an 1984 Sport Coupe
is there a switch somewhere inside the steering column which can short out ?
Old May 5, 2005 | 01:16 AM
truckpuller's Avatar
Default RE: Ignition Problems
The ignition switch is on the top side of the steering colum under the dash and controled by a rod from the key switch. I have seen the wire connector for the main feed come loose and get hot and melt the switch and cause bad connections.
Hope this helps and let us know what you find
Old Aug 22, 2005 | 05:36 PM
copman1972's Avatar
IS IT A GREY AND CREAM COLOR AND SIT ON THE RIGHT SIDE OF COLUM
Scott Beam
Jan 14, 2011 11:22 AM
stlrams28
Jun 25, 2007 10:17 PM
mugglesluvford
Feb 21, 2007 07:19 PM
NicksMeanGT
Nov 1, 2005 08:46 PM
Frosty4422
Jun 22, 2005 04:29 AM
