2003 F250 rear View Mirror Problem
Old Jun 4, 2007 | 12:21 PM
ovh's Avatar
ovh
Default 2003 F250 rear View Mirror Problem
Hello. I need to remove my rear view mirrior on my 2003 F250 but I have NO idea how to do it. Do I need some special tool like my friend says I do? Please tell me this isnt the case.
Old Jun 4, 2007 | 02:39 PM
Default RE: 2003 F250 rear View Mirror Problem
The complete mirror assy? or mirror glass for repair?
If the assy.. Just open the door, look just ahead of where the mirror is in the jamb.. You'll see 3 rubber plugs.. Remove the upper/lower to access the 2 outter bolts.. Pull/unsnap the black dress cover and you see the other 2 nuts through the access holes behind the insulation tape..
For the mirror glass (I'm guessing TT mirrors) you'll need a door trim panel tool, or something fabricated to remove/pop loosethe jack pin ***** from their sockets in the head assy.. Repair kit will have eveything you need to complete the install..
If its the mirror glass, I'll post some pics to help with the job if needed...
Old Aug 21, 2010 | 10:02 PM
kwidav's Avatar
Smile removeing rear view mirror ford 250
ford has a special tool to remove it. i got mine off with a .028 feeler guage. you have to file about a 1/8" off the side of it because its to wide. then just slide it in the hole in the bottom of the mirror.wiggle the mirror side to side wile pushing up on it. should pop right off.you can get the feeler guage at sears or any auto parts store for about 6 bucks.
Dr76
Jul 30, 2010 10:25 PM
antced1
Apr 1, 2007 09:51 PM
LuxSpsort
Mar 9, 2007 12:33 PM
klahay
Mar 5, 2006 08:40 PM
DRP2000
Feb 7, 2006 09:29 AM
