wheel noise?
Old Jun 12, 2007 | 10:45 PM
dmil74's Avatar
Default wheel noise?
noise coming from fr. pass. wheel. could a warped rotor cause noise? this is a 98cv P71. doesnt seem to be getting any worse. any help appreciated.
[align=left] [/align]
Old Jun 13, 2007 | 10:22 AM
flyboy's Avatar
Default RE: wheel noise?
What kind of noise? Grinding, scraping, rubbing? A warped rotor will be felt when you apply the brakes, (a surging sensation usually), I had one of them in my Sport. Find a frame lift so you can turn the wheel manually & look & listen for the sound.
Old Jun 13, 2007 | 07:33 PM
way2old's Avatar
As flyboy stated, the sound of the noise is a key issue in diagnosing. If it is a slight squeaking, look at the hubcap if it has full wheel covers. If it is a roaring noise as you drive it, look to the wheel bearing. If it is a grindg noise, look to the brake system.
Old Jun 13, 2007 | 08:25 PM
dmil74's Avatar
thanks for the ideas. i'll have to look and listen a little better.
Old Jun 16, 2007 | 07:00 PM
dmil74's Avatar
hub cap seemed tight, but made a rattle noise compared to other wheels.
added a couple of cable ties to secure better. problem solved. thanks
again.
bobk51
Nov 16, 2014 09:16 AM
Harburmaster
Feb 16, 2009 09:12 PM
broncky
Oct 8, 2007 07:59 PM
broncky
jake3020
May 3, 2005 01:22 PM
