Probs with "Upstream air sensor"
Old May 6, 2005 | 06:46 PM
kiltwearinfool's Avatar
Default Probs with "Upstream air sensor"
Hello y'all, I have a '97 4-door 2.0 5-speed with about 120K miles. With regular maintenance it's been a good little commuter car for me for about 5 years now, but it recently developed a problem that's proving difficult to diagnose.
About 3 weeks ago while I was out of town the "Service Engine Soon" light came on. I took it into a Midas shop to see if they could give me an idea of what was wrong. The fella told me OK, but there were some issues he could not fix, only a dealer could.
He plugged in his OBD reader & got the code. Unfortunately I did not have him write it down, but he told me that the code translated into a "Problem with the upstream air sensor" and that the car was running lean.
I had been experiencing some minor idling problems (rough idle after warming up for 12-15 minutes), but nothing major, no stalls. The Midas man told me this was a problem for the dealer.
While I took his word, I wanted to check things with my local independent mechanic. While not a Ford specialist, he does come recommended by a friend. He plugged in his own OBD reader, got the same message that the car was running lean. However, he was not able to localize the problem. He instead felt there was a leak in the intake system somewhere, and proceeded to "smoke" the car. Apparently this is an old-school method of traking leaks whereby a smoke generator is hooked up to the intake & the engine is observed for any leaking smoke.
So my local guy couldn't find anything. He reset the light and sent me on my way.
Meanwhile, I have been thinking of all the things I might be able to replace in effort of fixing the problem. I own motorcycles and bicycles, and do quite a bit of my own labor (from changing oil and brake pads all the way to rebuilding clutches and gearboxes on old Triumphs).
I found an Upstream air sensor on rockauto.com, and I'm wondering how difficult it is to replace. My Haynes manual does not list it, but I know it's somewhere on the intake/exhaust.
Anyone have any tips? Thanks in advance.
Old May 6, 2005 | 08:55 PM
solo_one's Avatar
Default RE: Probs with "Upstream air sensor"
I dont know how well the smoke method works, but I always found vacuum leaks by spraying starting fluid or carb cleaner around the intake and any vacuum hoses. Spray an area, wait a few seconds, and if the idle increases, you've found your leak. Good luck!
Old May 8, 2005 | 02:54 PM
truckpuller's Avatar
Mass air flow sensor maybe which is usally located in the air intake duct before the throttle plate.
Oxygen sensor is located in the exhaust pipes .
Good Luck
04SEL
Mar 27, 2013 05:10 AM
kenny 40ltr
Sep 17, 2005 12:00 PM
alexma21
Sep 10, 2005 03:02 AM
sethro
Jul 21, 2005 10:25 PM
Cwzanth
Nov 25, 2004 06:10 AM
