Brake Light problem
Old Jun 25, 2007 | 03:34 PM
SusanT62's Avatar
Default Brake Light problem
I was just informed by Ford Service Dept. that the two brake lights won't power up due to a broken part that is no longer being manufactured by Ford. It is: F8RZ-14489-ZB -- where can I find a replacement part if Ford is no longer making it? Or can we use a similar part from a different Ford? Lights were fine going in for the inspection but then I was told bulbs were out, then it changed to that this part is bad. Car runs perfectly except for this issue as it won't pass inspection without the two brake lights. Any help is appreciated. Thanks!
Old Jun 25, 2007 | 05:14 PM
Default RE: Brake Light problem
Is this a 98 Contour?
The F8RZ 14489 ZB will cross to a Focus brake switch connector of YS4Z 13480 AA
Old Jun 25, 2007 | 05:32 PM
SusanT62's Avatar
It is a 1997 Contour 4 cylinder -- will your suggestion still work? It is a great car -- only 55,000 miles on it -- and hoping my son can drive it for another year before getting a new car. Thanks!
Old Dec 30, 2010 | 06:29 PM
bodmd98's Avatar
You can fabricate replacement connector by buying a universal Ford multipin connector through your dealor. Use a small hand coping saw to trim away outer plasic so that the terminals line up with the male pins on back side of the turn signal switch which powers the brake light circuit.
kdepq500
Jan 16, 2011 03:46 AM
jenior71
Dec 17, 2008 12:07 AM
jfrizman
Aug 28, 2008 11:19 PM
remmington76
Jul 4, 2007 01:08 PM
Bill in Tampa
Jan 8, 2007 12:35 AM
