intermittent a/c problem
Old Jun 26, 2007 | 10:33 AM
wilty1's Avatar
Default intermittent a/c problem
2004 w/30K miles, a/c works on cold start then stops after awhile.Air flow which was initially cold/cool thenis no longer cool. Any thoughtsor info on similar problems would be appreciated.Thanks, Walt
Old Jul 31, 2007 | 10:49 PM
detroitmi's Avatar
Default RE: intermittent a/c problem
It's possible the last person who charged the AC system may have over charged it. Have a shop check it out. It will be worth the inspection fee if they drain the system and recharge it. Work with them and they will work with you.
planefella
Apr 27, 2011 01:26 PM
whiteface
Jun 25, 2010 01:52 PM
stumpjumper
Dec 18, 2007 07:35 PM
kstoecklein
Dec 8, 2007 05:15 PM
covington
Aug 3, 2007 12:14 PM
