02 Explorer - jerks into Reverse
Old Jul 6, 2007 | 01:57 PM
pgderm25's Avatar
Default 02 Explorer - jerks into Reverse
Our 2002 V6 auto Explorer has issue with tranny. Has about 75,000 miles now. Problem started in Oct or so of 2006. After starting vehicle, shift into reverse and it will take the trans. a good 3 or 4 seconds to actually engage into the gear, and when it does, you better have your foot on the brake because it jerks hard into reverse. It acts like this probably 80% of the time. Also noticed a few months ago that when driving, in D, engine will suddenly sound as if it's in neutral for a few seconds, then goes back to normal. This is when driving around 30 mph. Anyone out there having a similar problem, heard of this problem before, or have a suggestion on what could be the cause??
We had Exp in to our mechanics last month for non-related repairs and had them check the trans fliud (they noticed the trans problem too). All was fine with fluid.
Old Aug 10, 2007 | 11:46 PM
Default RE: 02 Explorer - jerks into Reverse
This stuff is best left to transmission shops. It could be that it just needs a filter and fluid change or band adjustment or it could be more complicated. Either way you'll save money by not letting a regular mechanic "monkey" around with it. You may also do a quick check of your transmission fluid (with the engine warmed up and running) to be sure you aren't losing any fluid. Either way if you start with the smaller ideas you may have a chance to get out cheaper.
Old Jun 19, 2012 | 10:45 AM
Ckmieciak's Avatar
you find a solution?
Old Jul 1, 2012 | 01:33 AM
mmerlinn's Avatar
Duh, if he had found a solution and was going to post that solution, don't you think he would have done that FIVE YEARS ago when this thread was active?
At this point in time, it is doubtful that he will EVER see your question, especially since he has made ONE and ONLY ONE post ever on this forum. He is probably long gone from this site, and also probably long gone from this vehicle. And even if he ever came back, he probably could not remember the solution in enough detail to help you.
maxpower
Jun 24, 2013 08:58 PM
SSJAKE95
Dec 15, 2010 07:32 AM
SSJAKE95
Aug 9, 2010 07:48 PM
Soar1000us
Feb 7, 2010 12:12 PM
LetsGoCellular
Jan 20, 2008 09:41 AM
