1998 Contour fan in-op?
Old Jul 10, 2007 | 03:02 PM
Fredo's Avatar
Default 1998 Contour fan in-op?
Just bought a 1998 Contour Gl 2.0L. The heater/A/C fan is in-op. I was going to check the fuse.
but I do not have an owners manual. Can anyone help?
Old Jul 20, 2007 | 11:10 PM
Default RE: 1998 Contour fan in-op?
You can download an owners manual here.. https://www.fleet.ford.com/maintenan...ls/default.asp
Also check the blower relay, the heater/fan blower resistor...
[IMG]local://upfiles/6756/141554277B1B437CBAEE03A7D6A86BD9.gif[/IMG]
Old Jul 21, 2007 | 08:17 AM
Fredo's Avatar
I checked the fuse and the relay, both are good. Anything else I can check?
Old Jul 22, 2007 | 11:00 AM
Fredo's Avatar
I checked the power to the heaterfan motor itself and I am getting power to it. I assume the motor is bad. Does anyone know how to remove it? I do not see any screwson the motorto remove it?
Old Jul 22, 2007 | 11:36 AM
Blower Motor
Removal
1. Remove the pushpins for the upper footwell trim panel on the passenger side and remove it.
[IMG]local://upfiles/6756/4402B8F5BDEE4093800488C77CED33A6.jpg[/IMG]
2.Remove the blower motor.
Disconnect the electrical connector.
Lift the securing tab slightly.
Turn the blower motor approx. 30° counterclockwise and remove it.
[IMG]local://upfiles/6756/34119D9712C04B679AAD82B6051FD3D6.jpg[/IMG]
Installation
1. NOTE: Engage the securing tab for the blower motor.
To install, reverse the removal procedure.
[IMG]local://upfiles/6756/96A044B9CBF24C33ACA17865D224679B.jpg[/IMG]
Old Jul 22, 2007 | 11:44 AM
Check for 12v and an applied ground for blower function/operation before replacement
Old Aug 5, 2007 | 11:35 AM
Fredo's Avatar
Thanks, it was a bad fan motor.
Old Aug 5, 2007 | 01:08 PM
Thanks for the update....
CharlesC
Feb 14, 2013 12:07 PM
BigChevy80
Feb 11, 2012 05:09 PM
hunniebuzzu
Feb 7, 2008 12:58 PM
95se_mexican
Dec 16, 2006 06:52 PM
Harry
Nov 6, 2006 04:16 PM
