99 ford escort engine problem
Old May 12, 2005 | 10:45 AM
peternellad's Avatar
Default 99 ford escort engine problem
riding my ford the oil light went on and the car engine cut off.
I change the oil filter and fill it up with oil. the oil pressure went up but the car is working like is missing one cylinder'
I have change the spark plugs and also had my injectors clean and also I have meassure the cylinder pressure to verify that there are no broken rings or problem with the valves, that was oke.
Went pressing the throttle and getting half way it began to lose like power and also my brakes are very hard.
Any help that can help me out.
Old May 14, 2005 | 09:47 AM
solo_one's Avatar
Default RE: 99 ford escort engine problem
The hard brake pedal is a sure sign of a vacuum problem. Check all your hoses.
Old May 14, 2005 | 02:52 PM
I have check all the hoses all are good I also change the PCV valve.
Is there any more help
Thanks,
palmerckd
Apr 10, 2011 05:42 PM
90EscortSTH
Mar 27, 2011 10:27 PM
twobig86
Sep 3, 2010 08:37 PM
crailcramer
Sep 1, 2010 09:00 AM
