98 Ranger 4x4 clunks when starting from stop
Old May 13, 2005 | 12:49 AM
derding's Avatar
Default 98 Ranger 4x4 clunks when starting from stop
Anyone else ever heard of this problem? My drive shaft has been replaced 3 times now, and after a few months it develops a clunk again. I'm wondering if others have had this problem and if there is a permenant fix? Thanks....Dan
Old May 13, 2005 | 04:55 PM
Spectre's Avatar
Default RE: 98 Ranger 4x4 clunks when starting from stop
I have a 1995 4X4, and I understand it is fairly common. My mechanic just removed the universal, and applied a very heavy grease to the splined shaft at the transmission end, where it is designed to slip forward or back, and this lessened the problem greatly.
Old May 13, 2005 | 06:11 PM
Patrick's Avatar
Administrator
i would agree with a U joint issue, and make SURE it is always kept lubed.
Old Jul 20, 2005 | 08:56 PM
jack2290's Avatar
what you may have is spring wrap. That drove me nuts. Yeah grease the drive shaft . works only for a while. Bought james duff traction bars cured the problem..l
Old Jul 21, 2005 | 03:32 PM
I have to ask how much play up an down on this part of the shaft you get,, There shouldnt be any, they use to coat these splines with a teflon base coating that was fairly thick, if that has worn off, an or the splines are worn , then you got problems , Most Driveline shops should be able to reapply the coating if thats all it is , As for the grease as you see its only a temp. fix its filling in the gaps. I would get this checked out , also it's possible that the shaft might be a tad bent , an thats causing it pop when it finally slides past that spot .An also is this the rear drive shaft or the front ?????? , As this problem is also very common on the front shaft as there a smaller DIA. An usually its from folks running around with it locked in 4 wheel high
Old Jul 22, 2005 | 03:24 PM
Spectre's Avatar
My 95 did that. Actually, I think they all do. My mechanic told me it as normal.
Sage
Mar 11, 2010 07:52 AM
helpford
Nov 12, 2008 11:35 PM
country2
Apr 3, 2008 09:21 AM
sam109
Jan 27, 2007 04:06 PM
sam109
